Delete of the displayed container structure instance failed as the displayed field was not empty. This is an internal error and can indicate either a memory corruption or a software bug that can cause a memory leak.
If this condition persists provide technical support information on Identity management configuration and details of the error message. Also, check the scalability limit and compare this with the current configuration.
Error
Failed to delete %cont% with non-empty field %field%
| Name | Type |
| cont | String |
| field | String |
